Hi everyone, what’s the best way to fix cracks in the mortar between bricks on a house? Also, are there any good ways to protect bricks from water damage or weathering?
Repairing and protecting brickwork
Hi there!
Fixing cracks in the mortar between bricks is pretty straightforward. The process is called repointing. Start by carefully removing the old, crumbling mortar to about ½ to ¾ inch deep. You can use a chisel or a small grinder for this, but be gentle so you don’t chip the bricks. Once the gaps are clean, brush out any dust or debris. Mix up some mortar that matches the original in color and texture (you can find pre-mixed options to make it easier). Use a small trowel to pack the new mortar into the cracks, pressing it in firmly, and smooth it out to blend with the rest. Let it dry according to the instructions, and you're good to go!
To protect your bricks from water damage, consider applying a breathable brick sealer. It keeps rain out but still lets the bricks "breathe" so moisture inside can escape. Also, keep your gutters and downspouts clear, and make sure water isn’t pooling near your house. Regularly checking your brickwork for damage can help catch small problems before they get worse.
You're welcome! Matching the color and texture of the mortar can be a bit of an art, especially with older brickwork, but there are some tricks to make it blend seamlessly. First, take a small sample of the old mortar to a hardware store or masonry supplier. They can often help you identify the right type of mortar and pigments to match the color. If you're mixing your own mortar, start with a small batch and test it on a less visible area to see how it looks when it dries since wet mortar often appears darker.
For the texture, try to match the sand in the old mortar as closely as possible—it plays a big role in the final appearance. You can experiment with different types of sand to mimic the original. When applying the new mortar, use tools that are similar in size and shape to those used for the original work, and make sure to tool the joints to match the existing style (e.g., concave, flush, or raked).
If the brickwork has aged or weathered, consider lightly brushing the new mortar with a damp sponge or soft brush after it has started to set. This can help it blend with the surrounding area. Over time, natural weathering will also help it match more closely.
Appreciate the advice, sounds like it’ll take a bit of patience to get it just right.
You're welcome! I agree, it can take some time to get it just right.
If the sand texture in your area isn't an exact match, don't worry too much. You can try to find a similar sand by checking local suppliers or even experimenting with different types to see which one gives you the closest match in color and texture. If that's not possible, you could adjust the overall texture slightly to give it a more consistent look, especially if it's for a smaller or less noticeable area. Sometimes, mixing two or more sands can help achieve a better blend.
