Chamberlain won't open all the way
  • carfi
    • Mar 2014
    • 4
    I recently replaced an old Liftmaster opener with a new Chamberlain chain drive. After completing the installation, the trolly stops about 3 feet short of the stopping point on the track. The door closes fine. If I pull the emergency handle and disconnect the door from the opener, I can open and close the door just fine with no issues. I've tried adjusting the force limit settings on the opener itself, but this does not help. Any ideas?
  • TJR
    • 175
    You need to adjust the open/close limit, done on the left side of the opener, two white dials. Reset you force settings.
    • carfi
      • Mar 2014
      • 4
      Thank you for your reply, however as you can see in the op, I have tried that already. It will not go all the way up regardless the setting on the limits.
      • Garagegadgetry
        • Mar 2014
        Force limits and open/close limits
        There are two sets of limit adjustments. The blue dials are for the force. What you need are the open/close limits. This will be located on the side of the unit. If you have a unit with two lightbulbs it will be located on the opposite side of the motor from the force limits. Locate the one with the picture of a garage door and an up arrow turn this in small increments until your door opens to where you want.
        • carfi
          • Mar 2014
          • 4
          Now I feel like a complete tool. I didn't even check the other side for adjustments. I'll try it out tonight when I get home. Thank you in advance
          • carfi
            • Mar 2014
            • 4
            AANNNNNNNDDDD Fixed. thank you again for your help. I can't believe I overlooked this.
