I have a Python 2 garage door opener. The door will not close using either the remote or wall control. The door will open back up after traveling a short distance.
Holding the control button does not force the door to close. It bucks after a short distance and goes back to the open position.
I am not sure what else in order to repair the door closing. Here is what I have found out:
1. The door opens without an issue whether via the remote or wall control.
2. When the door closes, the sensor lights DO NOT blink or indicate that the door is not closing due to the sensors detecting an obstruction. (The sensors appear to be functioning as expected in terms of their lights not indicating any problems at any time.)
3. I replaced the door close control and wires.
4. I replaced the logic board.
5. I reset the location of the door open and door close stops.
6. The door's balance seems fine based on how it closed in the manual mode from a short height.
7. There do not appear to be anything on the tracks that would cause a problem, and the door opens normally.
8. The force close setting has been adjusted even to its highest setting without
I would certainly appreciate any ideas on what else to try.
Thanks.
Thanks.
