I just replaced and at the same time made my garage door opening bigger. The original garage door was 6'9". and we replaced it with a 7' door. The original header was a 2X8 that was doubled. We cut it out and put in a double 2X6. It is a two car garage that has 2 seperate doors. It is one floor with an attic. My neighbor said that the header was supporting the roof overhang, my question is, do you think that the 2X6's will be good enough to not cause any problems? I have not noticed any problems and the removal and installation went pretty smooth, I also needed a higher door for the garage, my truck did not fit before. I will need to do the other door this week and was wondering if I should go about it the same way or should I do it differently? Thanks
Garage door header replacement, problem?
