Genie 1/2 HP Model 2060L-07 Problem with screw
  • mawil1013
    • Oct 2020
    • 6
    Genie 1/2 HP Model 2060L-07,
    Won't open, screw chatters bad, looks like it spinning super fast or vibrating, Disconnected the door, door opens easy by hand. Engaged the screw to door connection and it goes back and forth easy, I push the screw to door connection and it is locked in, Everything works until I connect the door back to screw to door connector.
  • Downaski
    • 409
    It sounds like your Genie garage door opener is having some trouble with its screw drive system. The issue might be due to a misalignment or obstruction in the screw, a worn-out drive gear, or loose mounting hardware causing the chatter and vibration. Have you tried cleaning and lubricating the screw?
