Peeling Paint
  • Jacobs
    • Apr 2007
    Peeling Paint
    We have a home located at an elevation of about 9,000 ft. We continually have problems with exterior paint peeling on the wood trim around the south facing windows. When using the same paint on metal, we haven't experienced any problems. We have used both latex and oil based primer but neither bond very long onto the wood. I even tried reducing the primer thinking it would soak into the wood and thus bond, but even that didn't work any better. Does anyone have any sugestions? Is epoxy primer available and if so would that bond better?
    • 8747
    try a product called KILZ. Made by a company called Zissner it is an alcohol based primer that takes well to oil base and latex.
    • Jacobs
      • Apr 2007
      Thanks HayZee, I'll try it.
      • wvguy
        Painting, Decks and Fences Moderator
        • Apr 2007
        • 72
        i would consider different primer
        people get hung up on Kilz but i tell u its not all that. Plus I wouldn't recommend it for broad surfaces outside, only for spot priming due to the way that it dries: by interlocking.
        I would use an exterior oil whole house primer.
