Suggestion on what to use
  • DD716TED
    • Nov 2004
    • 220
    This spring I want to paint about 200 linear ft of wood fence constructed of 6" x 6' boards. I will only be painting one side as the neighbors have kept the other side fairly well over the years.. I will be using a color latex based paint. I want to spray it as the last time I did it by brush / roller and it took all summer.. What would be a good but inexpensive sprayer to buy and use? I would buy a sprayer and probably not use it again for another 5 years or so I don't want to spend a fortune on it just to spray a fence.. Harbor Freight? Any and all suggestions will be greatly appreciated.. Thanks
  • handyandy
    • Sep 2002
    • 210
    Hi,
    I would go with the Wagner Spraytech Handheld Paint Sprayer or the GoPlus Paint Sprayer if you are looking for inexpensive. They are both under $100. If you are willing to spend more than that, then let us know and I would have different recommendations.
    Good luck with your fence!
    • annajohnson
      • Jun 2022
      • 5
      You can also go with the HomeRight Paint Sprayer or Paint Zoom Paint Sprayer. Both are readily available on Amazon. Also, If you are not ready to spend on a sprayer for one-time use then you can also go with some expert Fence cleaner/painter who will definitely do your work neatly.
