Clear gloss Poly over satin nitro?
  • John Parker
    • May 2022
    • 16
    I just bought a black double bound body with a satin nitro finish. I would
    like to bring the gloss up can I spray a gloss poly over top & do I need to tape the binding or can I spray over top?
  • Irwilliams
    • Jul 2022
    • 17
    Generally, it isn't good to mix types of finishes. You'll have all sorts of issues. The poly won't stick well.
    Sometimes when you mix finishes, you'll even have a chemical reaction where it won't cure (leaving a sticky mess permanently), or will start bubbling.​
    We answer how to use gloss polyurethane over satin finish. Detailed instruction and tips on how you should do this for best results.
