About a year ago I ran across a simple free download program called "Primo PDF".
Once the Primo PDF program is installed you can quickly and easily convert any file to PDF. To convert you open the file in your normal manner. When the file is open you then hit "print" and a box drops down asking you to select either your printer or the Primo-PDF converter". You select the converter and hit return and the file is instantly saved in PDF format.
As I stated above, i have been using this program for over a year with excellent results and no spam or pop-ups.
It is a free download from:
PDF Converter — #1 Free PDF Creator — PrimoPDF
It should be noted that this is intended to be a personal use program. They offer a more in depth program for commercial use at a small fee.
