i am doing the structured wiring thing and was wondering since my home runsweren't quite long enough will i loose very much by using female-female couplers ?
cat5e couplers
Tags: None
The General Contractor we hired is a real dick.He wanted to terminate all this stuff, telephone, ethernet, video, cable and satelite right next to the electrical panel. Anyway, he never asked me what I was trying to accomplish. so the cat5e terminates about 5 feet from the panel and i need to go maybe 10-15 feet elsewhere-anywhere but near the panel. so a 110 block will allow me to use a punch down tool to make a splice and get on with my life?quote:Originally posted by Troy
If you make a good connection, then it shouldn't be a problem. I wouldn't recommend it, but you'll probably be ok. If you are joining more than a few wires, then I would use a 110 block to connect them.It\'s sometimes better to be lucky than smart.Comment
The 110 block will give you a way to securely connect the wires. It will also give you a place to mount and secure the cables so they don't get snagged. Make sure you get a 110 block rated for cat5e and you should be fine. Just punch them down!
Let us know how it goes
Tr
yComment
Quick question, please.
With a 110 punchdown board, is it advisable to repunch if mistakes are made? How does this affect the terminals and connectivity? Is there a special technique to remove terminated wires without damaging the terminals?
Thanks.Comment
I decided to use the 66 block instead but for the telephone;and to join the 2 cat5e i simply put male connectors and used a female female cupler to join them and the line continued to the terminus (router/switch/modem stuff)
As far as reconneting, I have miswired something on the 66 block and just carefully pulled straight up on the wire to dislodge it from the IDC, i do not know if this is ok but i haven't felt anything ....perhaps someone else could elaborate.[quote]Originally posted by allthumbs
It's sometimes better to be lucky than smart.It\'s sometimes better to be lucky than smart.Comment
by halikidHello everyone.
I’m looking into different water treatment options and recently came across Hiju Water Treatment. I’m curious to know...-
Channel: Everything Else
