Bearing like noise as machine starts to slow down from spin cycle, The noise decreases as tub slows down to a stop. No noise when actually on spin cycle or any other cycle just after spin finishes and tub is slowing down. Under side of machine, belt and floor is covered in a black grease like substance. Can not duplicate noise by spinning tub by hand
![IMG_20250703_054125253[1].jpg Click image for larger version
![IMG_20250703_054510971[1].jpg Click image for larger version
Tried hand spinning machine with bottom belt cover and with belt both on and off. Unable to duplicate noise. Bottom smooth pulley has a lot of side to side play. Pulled off pulley and same play in actual shaft side to side.
