Our Dishwasher is flooding our kitchen. The water from the water inlet valve does not stop letting water in. Had to turn the water off to stop the water from flowing. Any suggestions?
Kitchenaid KUDS01FLss1 water pouring in from water inlet
Check while disconnected from power
If the dishwasher continues to fill with water even while unplugged from power, the water valve (see the following link) is stuck open and likely needs to be replaced.Originally posted by WalkersThe water from the water inlet valve does not stop letting water in.
LINK > Kitchenaid KUDS01FLss1 Water Fill Valve
If filling with water does stop when power is disconnected from the machine, some part(s) of the control system would need to be investigated. That however is unlikely as both the control and the float/overflow prevention switch would both need to be malfunctioning to result in overflowing.
Appliance411.com
.Last edited by Dan O.; 02-27-2013, 11:47 AM.Comment
Channel: Appliances
