The dryer on my 1997 Kenmore electric Dryer model 90, burned up. It came with a black terminal block on it. The only identifier on the block is SAE, PPS, GF, MD. The white connector that mounts into the block has a tag on it that says 1/6/7148 and under that, 3398958.
I am trying to replace the motor with a 1994 Whirlpool motor which is identical except for the terminal block. The numbers on the motor appear to be GFF479008. The terminal block is an oblong box with only male connectors coming out whereas the Kenmore terminal block is sort of l-shaped and the the white female connector plugs into it, preconfigured.
Would anyone be able to tell me where the wires from the newer block would connect to the 1994 block ?
Rein
Rein
Sorry dont have them... the diagram for the bad motor should be under the console.... Sorry
