Exchanging dryer motors
  • Rein
    • May 2004
    • 5
    The dryer on my 1997 Kenmore electric Dryer model 90, burned up. It came with a black terminal block on it. The only identifier on the block is SAE, PPS, GF, MD. The white connector that mounts into the block has a tag on it that says 1/6/7148 and under that, 3398958.
    I am trying to replace the motor with a 1994 Whirlpool motor which is identical except for the terminal block. The numbers on the motor appear to be GFF479008. The terminal block is an oblong box with only male connectors coming out whereas the Kenmore terminal block is sort of l-shaped and the the white female connector plugs into it, preconfigured.
    Would anyone be able to tell me where the wires from the newer block would connect to the 1994 block ?
    Rein
  • TiredSearsTech
    • Apr 2004
    • 11
    Numbers on the wires match the numbers on the term block.. you need both wire diagrams for each motor .. less headache getting the right motor....
    • Rein
      • May 2004
      • 5
      TIRED TECH:
      Any chance you can fax the wire diagrams for each motor to 512.327.3644 ? Sure would appreciate it.
      Rein
      • Rein
        • May 2004
        • 5
        Anyway you can fax the diagrams for both motors to me at: 512.327.9310.
        Rein
        • TiredSearsTech
          • Apr 2004
          • 11
          Sorry dont have them... the diagram for the bad motor should be under the console.... Sorry
          • Rein
            • May 2004
            • 5
            Thanks, I didn't see it on the back as with the old dryer.
            Rein
            • BonesandFeathers
              • Apr 2004
              • 29
              Please look on the door/frame and get me the part number for the dryer. it is 110.xxxxxxxxx
              I can research the part number better. Also do you have any idea what p/n dryer the old motor came out of?
              Paul
              • Rein
                • May 2004
                • 5
                The motor p/n is 279827, "used on many Whirlpool and Kenmore dryers". The dryer I am trying to fix is a Kenmore series 90 made in 1997. I had an electrician friend of mine check the motor and it runs so he says that the Capacitor is gone - the motor runs in both directions. Around here (Austin) it's tough to find just the capacitor or the centrifugal switch. Any ideas ?
                Rein
