Do any of you have any great systems for organizing and storing sandpaper, sanding blocks, steel wool, and other sanding/grinding materials?  I just have everything thrown in a box and I can't think of a good way to store them.  Thanks!
sandpaper, steel wool, and sanding blocks
 Great suggestions! I might end up using both of those. I can make a less bulky version for quick sanding that I store in a close-by cabinet, and a slightly more bulky version that I store all of my sanding supplies, steel wool, and blocks in. I should be able to use hanging files and a plastic hanging file storage box from a local office supply house. Thanks! You guys rock!
 if you want a weekend project get some 1/4 inch ply and make a holder for the sandpaper. make it stepped like the booze bottles at your local tavern. Use plastic coffee containers for the steel wool pads and write the grit on the can. Sanding blocks You can use velcro on the handle back and stick em to a board.
