We had a new addition put in in 2003.
We have 3 out door outlets each with a GFCI duplex.
Tracing all the wires it appears from the 20A breaker in the panel the YELLOW 12A romex goes to an outside GRAY junction/switch box where (3) branches are pigtailed together, and go in their own directions: One is gray outside romex to an OUTSIDE receptacle and the other 2 are yellow 12A that go to receptacles on the side of the house.
Since I can't get the house receptacle GFCIs to reset, I had to figure out what was happening so I hooked up a regular 15A duplex on one of the house branch receptacles and tested says it has an open neutral. The 2nd branch won't light up at all cuz I can get it reset the GFCI.
I want to get a much larger JBOX and rewire everything. This tiny little box seems so small for a GFCI AND 4-12A cables to be pig tailed in there....
I guess I could start there....
QUESTION: Since all 3 branches are PIGTAILED, if there was a ground fault on one would it necessarily trip the others? ( the 3rd OUTSIDE outlet is a considerable distance from the j-box.
Should I have a CFGI at the breaker instead?
Thanks in advance.
Thanks in advance.
