Yes adding blocking and stapling to the blocking within 6-8" of the box will pass inspection.
what to do with wire after removing wall?
 stapling to the face of the joist is no problem IF there is no chance of hitting the cable. the accepted practice is to install a nailer, like a piece of furring strip to the joist, then stapling the wire to the nailer. at least there is some support for the cable. drilling through the approx center of a joist is also permitted. hole diameter is about 5/8" or 3/4"
 Thanks a million to both of you for your advice and time to help people on these forums out!!
 You will be seeing more of me around, unfortunately every ceiling tile I drop has a nightmare hidden behind it
 I am starting to wonder if there was ever any "legal" work done to anything in this house...
 see you soon
