How would I add a switch so the fan won't run 24/7? Thanks.
Panasonic exhasut fan switch
Your schematic wiring diagram shows a "Switch Box" with an On/Off switch in the "Live (vent)" 120VAC wire. Does that switch exist in your installation? The On/Off switch is usually located in the vicinity of the exhaust fan. If you want to install another switch, it would be in that wire (which in most cases is black).
