Outdoor Post Lamp
  • Tom Perkowski
    Outdoor Post Lamp
    I have an outdoor post lamp that has worked for years. It recently stopped working and I changed bulbs, which is the usual solution. It did not solve the problem. After changing the bulb, switch, checking continuity, circuit breaker, the problem seems more complex. We measured 120 V at the switch, the lampholder has continuity but when measuring voltage at the lamp, it only registers 8 - 10 volts. When checking operation at one time, the light came on for several seconds and then went out.
    The switch is in a four gang box and we discovered that the line inside the post is actually lamp cord.
    Any help would be appreciated.
    If i found lamp cord in the post i would suspect that someone installed it as a do-it-yourself project and didnt do it right. I think i would first find out what kind of wire is run from the house and replace it all if necessary
    • volts
      • Mar 2004
      • 68
      Tom: I shudder to think that common lamp cord was used to power the pole lamp and probably running back to the feed source. Yes, a rewiring job is in the offing.
