THHN Cable
  • hummas
    • Aug 2004
    THHN Cable
    Hi,
    Can THHN cable be ran inside a wall from a entry point from outside (using conduit) to a breakerbox about 3 ft away?
  • hummas
    • Aug 2004
    quote:Originally posted by hummas
    Hi,
    • hummas
      • Aug 2004
      Hi,
      I think I have confused the question. Can you run THHN cable in walls between 2X4's without conduit? I cannot seem to find that answer in the NEC code book. Any help would be great.
        THHN THWN is a single stranded conductor. It is available in a multitude of colors. It CANNOT be run by itself exposed within a wall or outside of the wall i.e. stapled to the studs, wallboard or other. It is meant to be installed in a suitable raceway - EMT, RIGID, PVC, WIREMOLD. Purpose of the raceway is to afford mechanical protection. Even if the wire is installed inside of the wall (technically) it is unprotected.
        • hummas
          • Aug 2004
          Wow!
          Outstanding response time and worthy website.
          Thanks.
          I am so glad I registered.
          Thanks again.
          hummas
            Hummas, Welcome aboard and glad we could be of assistance. We will look forward to seeing you often and ask that you tell your friends.
