So, new home manufactured by Palm Harbor, with a garage added by contractor.
Climbed up on the roof to check on a flue cap for the water heater, and as I grabbed the gutter I got a shock that was pretty substantial.
I went and grabbed my meter, and just by sticking the common probe into the ground and touching the red to the gutter I got 66 - 72 volts.
Now, I am not an expert, but I'm certain gutters don't carry juice.
I checked the gutter on the other side of the house and got 108 volts.
Working with a partner, I shut off breakers until the juice went away.
The offending breaker powers the laundry room light, and two exterior lights.
So, I have no lights - but my gutters won't kill anyone either.
All four gutter downspouts showed voltage to ground, and none of them are connected together - the gutters are in four separate pieces.
The roof is wet, so maybe it is conducting? The gutter ends are each shoved into PVC that goes into the ground and a common drain system, so in theory they are somewhat insulated from the ground immediately around the house.
Thoughts?
Thoughts?
