Vehicule Tires left on Hardwood floor leaves bad marks...help
  • helpmewoodfloor
    • Dec 2012
    Ok look, i'm having a bad day ....
    I have left on the floor some winter tires. Now need to change them on the car and i see bad marks on the floor.
    It's like the contour of the tire left a print mark on the floor....
    I have tried all kind of stuff... magic eraser, lighter oil, degreaser of all sort .... now, the only option i have left was to sand the damn thing out...
    Obviously i just cant sand the wood floor because it leave bad marks on it ...
    What are my options.. PLEASE I NEED DESPERATE HELP...
    Here's some pictures
    P.S. The mark seems really encrusted in the floor...inside of it... The only method i was able to remove some was to sand the floor with 80 sand paper....
ID:	87679Click image for larger version
ID:	87680Click image for larger version
    tires
    yup, that the oils that leached into the wood. sanding is your only best bet. you could try acetone but you'll refinish the floor anyway.
    • LucacHumac
      • Dec 2012
      Please i need desperate help....
        floor
        get the drum sander and sand the whole floor. use fabulon for a finish
