Baseboards
  • kim62955
    • Feb 2005
    Baseboards
    I just had tile put down in my bathroom and new baseboards and quarterround. I started painting them and now there is a slight crack where the baseboard meets the wall. How do you handle that? I was thinking caulk but if I use a caulk how do I match in with the trim color?
    Kim
    Kim
    Caulking is made in a number of colors and usually they use the one that closely matches.
    • floorman
      • Jan 2005
      • 61
      Normaly just a white painters caulk is used to fill that space in the base and paint later on,if you can find a caulk to match then good for you cause it won't be easy[8D]
      Floorman
      floorlayers union local 1310
      Floorman
