Help! I have a gas furnace that will not cycle when I flip the on switch or when I turn the thermostat on. Do I need a new thermostat?
furnace will not turn on
"Jump the R & W"? I don't know what that means. I am new to this...sorry!
quote:Originally posted by Hube
Dee; The best way to eliminate the T stat as the problem would be to check if there is power (24V coming into the therm) . if there is, then you can "jump the R and W, and see if it allows the burner to kick in. Keep us posted. HubeComment
dee, R&W in this case is a reference to Red and White wires that connect to the back of your thermostat.quote:Originally posted by dee
Thanks. Is there a special tool I need to do this?
Simply touch the two together and the furnace will begin it's cycle.quote:Originally posted by dee
If the furnace dose come on then RECHECK all the thermostat conections
to see if perhaps you only had a loose wire.
Depending on the thermostat type you may also have dirty contacts/connections.
Channel: Toyo Heaters
