Just signed up to try and get some answers to my problem here:
Here's the deal, I have a 5 year old he Gibson furnace made by Nordyne. Here is what it is doing and what I have done to try to fix the problem:
Calls for heat
Induction fan runs
Igniter glows
Gas valve turns on
One or two of the six burners light for 3 sec. and then it shuts off
Induction fan continues to run and it cycles 4-5 times before shutting down and red light blinks 4 times to say that ignition problem. Once in a great while it may light on it's own but it's very hit or miss.
I have cleaned out the burner area and cleaned all the orifices. Here's the tricky part, if I hold my hand over the induction inlet just before it lights and quickly take my hand away before it detects no air flow, it will light. It may stay lite through the whole heating cycle or the flames stop part way through the cycle. There is no pipe going to the outside, the induction inlet pulls air from basement (why they did it this way is beyond me). Any ideas??
Thanks,
Tim
Calls for heat
Induction fan runs
Igniter glows
Gas valve turns on
Thanks,
Tim
