Bryant 350 MAV - Replacing collector box drain tube
  • ricpaq
    • Dec 2011
    The lower collector box drain tube on my furnace is leaking water due to cracking. My local HVAC shop sells a rubber hose replacement kit for $85.00. That's too much. So, they told me to use the upper hose in place of the lower hose. But I found that one to be cracking also.
    What kind of hose product can I use as a more cost effective alternative? How do I remove the inducer housing for better access to these hoses?
    Your help is very important to me since water could possibly leak on the circuit board.
  • paul52446m
    • Nov 2009
    • 690
    could you show me some pic. of these hose's? I just go to the hardware and buy a good clear heavy tubing so it won't kink when you curve it. Paul
