Outdoor Grill Vent Hood Placement
  • handyandy
    • Sep 2002
    • 210
    When the contractor mounted the vent hood to the wall, it only covers the back of the grill. So when smoke is coming off the front of the grill (which is usually the case) it doesn't go up into the vent hood, but instead into the ceiling of my screened porch. Shouldn't the vent hood be directly above the grill, rather than its location being defined by its placement on the wall? I just don't know if it should pull that smoke into the vent if it isn't directly above the grilling area. Have you ever seen a vent hood mounted to an extension of the wall, instead of the wall itself? Thanks!
    hood
    the hood is usually fastened to the bottom of a cabinet mounted over the range. either case a free standing [hung] or cabinet mount should have enough of cfm-s to suck fumes outside.
