AC leaking water in house, etc....
  • Amy1
    • Jun 2004
    A motor had to be replaced last year because a large amount of water was leaking, soaking the furnace and everything below. We have a Lennox G40UH(X)Series. The unit is 2 years old.
    It stopped cooling the house last night. The air blows cool, but not cold and does not cool the house at all. I don't know a thing about AC units! I'll try my best to explain it. Above the furnace is where the air gets cold before blowing into the house, that part is leaking a small amount of water (not as bad as last year). That part was not replaced when we moved in 2 years ago, I don't know how old it is. That part of the air unit is behind panels that are bolted on. The front panel is cold and has heavy condensation on it, the right side panel is warm. Also the line that comes in from the outside unit (the line is wrapped with insulation tubing) has parts of the line that have ice clear around it, like ice rings. The ice is melting making water drip, this line is in clear view in my laundry room. I have turned the unit off because I don't want to further damage it, it wasn't doing any good on anyway.
    Also, I checked the hose that leaks water into the drain and it seems to be working fine, i blew into it and it seemed ok, some dust/dirt came out but water was coming out before that too. What do you guys think is happening?
  • imeduc
    • 330
    If you saw any ice or frost on the copper lines there. If so you could be low on freon in the unit. Is you filter clean??
    • Amy1
      • Jun 2004
      the air filter needs to be change. i usually change it around the 15th each month.
      So if it's low on freon can i recharge it myself? Is that something that's easy to do? Is it similar or the same as doing it to a car AC?
      • imeduc
        • 330
        On the car yes you can that is R134 but not on the AC you have to be EPA to work on a AC in a home that has R 22 freon in it .You cant buy R22 if your not EPA for it. If the filter is clean the coil clean the blower ok then you need freon for sure.
        ED
        • Amy1
          • Jun 2004
          Thanks for your help! I'll call someone in then.
