Hello, I have a Rheem RHQA1220THPAHANDEF indoor air handler and a Ruud UPCA036JAQ heat pump. The air handler works fine but the Ruud is no good and I am curious if I can replace it with a new Goodman model CPLT48-1 without a large problem...I was told the old heat pump was a 3ton unit and that the new one is 4 is that correct and will it work?
The connection will need a modification from 3/4" to 7/8" I did notice.
Thank you,
Nic
Thank you,
Nic
