Install of new coil onto support beam
  • pretzelb
    • May 2004
    • 25
    I was told my coil had become restricted and I needed to replace it. Instead of getting a like coil from the warranty I decide to upgrade to a "better" model. The warranty company paid some of the cost and I paid the rest.
    When the install team came they had to call back to the manager because the new coil would not fit. Compared to the original it was about 3 feet longer. I suspect that the home builder did not install the correct coil for my 5 ton system. At any rate the manager told the installer to cut the dividing area (plenum?) to shorten the space so the unit would fit.
    The new coil is installed and appears to work better than the other unit as my system has started to cycle again during the heat of the day. Originally my a/c would run from about 2 pm to 9pm without shutting off while trying to maintain 77 degrees.
    The problem is that I started to hear a loud thumping noise so I looked at the install. The coil is right up against a support beam that runs to the peak of my roof. After it settled in (and the install crew left) it began to vibrate and was beating against the beam. In the attic you can't hear it but in the house it's very loud.
    The coil is strapped to the beam to support the very end. There are more straps to other beams to hold the unit but this new strap was installed because of how much longer the new unit is. I think my other unit was a few feet from this beam so this strap wasn't needed.
    I "fixed" the problem by wedging a rag in between the end of the coil and the beam. This dampens the vibration. However I worry about the quality of this install. Specifically I worry it could damage the house in some way, which is probably a silly notion. To be honest the only way to avoid this problem would have been to pull everything in the attic and shift it all to the right a few feet, which would have been a huge project. I didn't want to bring this up until I was sure if I should be worried.
  • Hube
    • Nov 2003
    • 453
    In your estimation it is not installed right. So, either get them back to correct the problem , or live with it.
    • imeduc
      • 330
      With HUBE here for sure get them back now. Also are you sure you have a 5 ton blower on it. Id say if your unit was for a 5 ton coil then a 5 ton coil should fit on it with out all this rework
      • pretzelb
        • May 2004
        • 25
        Thanks for the advice. I bought the house when it was 4 years old but I begin to wonder if the compressor was 5 ton and the indoor part was something else. There was nothing on the inside piece to describe it so no one (who even bothered to check) could really be sure.
        At this point, I'd seriously pay double to have someone I could trust look at the entire system and fix it all. I've even considered paying for a brand new system and I have parts that are not even a year old. After having various problems every year for 4 years I'm a bit tired of it.
        Now to try and get them to send someone back who knows what they're doing.
        Thanks again.
          evaporator/blower units typically have squirrel cage fans which normally are very quiet and almost vibration free. If you have excessive vibration usually that is an indication of a restricted air flow. In your case i would suspect possibly the new unit is bigger than what the duct work was designed for. Whatever the cause, the bottom line is, there should not be excessive vibration so i would immediately contact the installers.
          • pretzelb
            • May 2004
            • 25
            The company sent a tech over and fortunate for me he was a good guy. He didn't move the unit but he did re-strap it so that it was pulled away from the beam and the weight was shifted elsewhere. The blower was also replaced because it was on it's way out.
            It wasn't all rosey though. He also put a drip pan on the unit but didn't reinstall a celanoid switch like I used to have. He also didn't dispose of my old unit but did disassemble it for me, which is more than the install crew did.
            Next time I learn to get more in writing up front. I know how the phrase goes but in this case assuming just reflected badly on me.
            One thing I did learn was that my attic has very bad ventilation. The tech said it was very bad compared to other houses he had been in. I am now looking into making sure my vents are clear of insulation and maybe getting better attic fans.
            • imeduc
              • 330
              For sure get the vents going for that attic. You need 1 sq ft for every 150sq ft of attic . With half in and half out. for the power fan up there . You need attic sq ft X 0.7=== CFM of the fan.
              Id dont get why they didnt clean the coil first?? Are why they didnt put a whole new blower coil unit in ???????? All so attic they did put a overflow pan under this whole thing there with a drain pipe to outside.
              Ed
                What was the purpose of the solenoid you say you had before?
                • imeduc
                  • 330
                  I think he means he had a overflow cut-off switch on the drain,
