I need to replace the steam (Cast Iron) radiator in my bedroom as the old one cracked (my house is from the 1940's). I can't seem to find anyone that sells them in northern NJ. Would anyone know of a store that may carry them? I would be willing to buy a used one also. Thanks
Steam Radiators
Tags: None
Look in your phone book for renovation or home improvement contractors and heating contractors. Often they are removing those old radiators and you may be able to find a real bargain on a used one.
You might also discuss your problem with a heating contractor. Most of the old cast radiators were we made with separate sections bolted together. They may be able to disassemble your radiator and remove the bad section.
You could also consider having it replaced with a modern baseboard steam radiator.
Channel: Toyo Heaters
