When the heat comes up in my apartment, the radiator in my dining room shoots off so much steam it turns my entire apartment into a sauna, and you can hear it from behind closed doors at the far end of the apartment. Help!
Radiator
It depends upon where the steam is leaking.
1. Leaking automatic air bleeder- turn steam valve off and replace the bleeder.
2. Leaking around the stem of the control valve- tighten the packing nut on the shaft under the control handle.
3. Leaking at the steam trap...tighten steam trap cover.
The following items will require a serviceman......
1. Cracked section- disassemble and remove or replace the section.
2. Boiler nipple leaking,,,dissassemble and replace nipple packing.
3. Leaking at stay bolt.. inspect through stay bolt, replace if broken..and replace seal.
Channel: Toyo Heaters
