system blows "warm" air only...not hot
  • hoosays
    • Nov 2003
    My a/c - heating system only blows warm (like room temp)air and kicks on every two minutes as soon as it shuts off. I have a split system with the air handler inside. Someone I know talked about heat strips? are they easy to install, like in a water heater? Or could the system just be dirty? Please help, money IS a problem!
  • imeduc
    • 330
    Not sure what you have if a heatpump and it cold out the air from them will feel cool. Try and push the tstat up or turn it on the AUX heat and see if the stripsheaters come on for you. Post back here with more info ,it helps
    ED[8]
      check your filter,,if its clogged up the high limit will kick the heat srips off
      • Hube
        • Nov 2003
        • 453
        Imo, it would not be caused by a dirty filter tripping the limit. If the limit is tripped the air would be hot, not 'only warm', as the poster indicated.
        Check out the fan/limit control for adjustment/replacement.
