Forced air furnace unit not blowing heat.
  • pjdudley
    • Jan 2005
    Make and model not known (nor do I see it printed anywhere on heater)
    I have a forced air furnace with cooling unit
    outside. When I switch it on for heat it would
    normally start out making a humming sound for
    awhile, then it would sound like it was lit and
    blowing flames, and after some heat built up the
    blower would come on and heat the house until
    the temp setting on the thermostat was reached.
    But lately I turn the switch on, I get the humming
    and sometimes the flame sound, but not always.
    But the blower never comes on. Sometimes
    when I would switch back and forth between off
    and on the blower does come on, usually for one
    cycle only.
    I had a similar problem in the summer with the
    air condition part of the unit. I would here
    humming but blower does not come on. Play
    around with the switch, blower might or might not
    come on. Finally it began to work correctly and
    lasted out the summer.
    Anybody have any idea where to begin tracing
    the problem ?
    advTHANKSance
    Paul
    sounds like the fan relay may be sticking.
    • imeduc
      • 330
      If you turn it to fan on at the tstat and the blower dont come on right away Id check the blower motor and capacitor also.
      ED
      • pjdudley
        • Jan 2005
        Thanks for the reply(s).
        I've noticed something else. I've used the circuit breaker box
        to power the unit off and on. The unit worked ok for awhile,
        sending nice warm air into the house for some time, although
        it stopped before it should ( I have the tstat set for 70,
        it would get up to around 60ish before quitting ) and then all
        I hear is humming, at which time I kill the c'breaker. Try
        again right away and only humming. Wait a couple hours and try
        and get warm again, but same as above...
        Paul
        • imeduc
          • 330
          Check the blower motor out
          ED
          • pjdudley
            • Jan 2005
            >ED
            Ed, could you please elaborate a bit. Not sure what I should look
            for. I just now came in after 5 hours away. I had left the c'breaker
            of. I just now flipped it on and it seems to work fine - but I know
            it will cut off at some point and sit there softly humming, at which
            time I kill it at the breaker box.
            Please tell me more, so I'll know what to look for tomorrow at
            day light.
            Paul
