I am replacing a mechanical thermostat for our central Ac / forced heat system (Ac is Trane XB 1000, Heat is Trane XE 80). There are (5)wires to the mechanical thermostat that are wired as follows;
1)Yellow wire to terminal "y"
2)Green wire to terminal "g"
3)White wire to terminal "w"
4)Red wire and blue wire to terminal "r"
The progammable thermostat (Honeywell) has the following terminals:
Y,G,W,R,Rc. (R and Rc have a factory installed removable jumper)
I am not sure what to do with the Blue wire that is attached to terminal "r" on the mechanical thermostat along with the Red wire. I see (3) potential options:
1) Leave the jumper in place and wire the blue wire to the "r" terminal along with the red wire as was the mechanical thermostat
2) Remove the jumper and wire the red wire to the "r" terminal and the blue wire to the "rc" terminal
3)Leave the jumper in place and wire the red wire to the "R" terminal and not use the blue wire.
Any advice is appreciated
