I have an A.O. Smith FSG 75 gal gas hot water heater. On very cold nights, a reverse downdraft is created in the fluepipe and it takes a very long time for the draft to change direction when the hot water heater fires up. During this time, the spent gas fumes are being exhauted into my basement.
Making matters worse, my fireplace flue shares the same chimney with the gas hot water heater. Yep - you guessed it, when I start a fire in the fireplace, the strong downdraft in the water heater flue sucks smoke down into my basement. The only way to avoid a smoky basement is to first turn the water heater way up to warm the flue pipe, then I'm OK to start a fire. Later in the evening however when the water heater cools back down and the draft again reverses, I again get some smoke in the basement, along with (I'm sure) spent pilot gas from the water heater.
Is there any way to add a "anti draft shield" into the 4' section of metal flue pipe that extends between the draft diverter and the basement wall? I'm hoping this would prevent the backflow of cold air into the basement when the water heater was not on. Also, can a draft inducer be added to a conventional hot water heater flue to help exhaust the hot gas fumes?.
Any advise would be appreciated. BTW, I pointed this out to the contractor when we bought the house - of course nothing was done about it.
