Two issues:
Issue 1: I really like the bit I put in my Dremel to cut holes in drywall: is there a similar tool for sheet metal, specifically the gauge used for home ductwork?
Issue 2: the ductwork has no place to put a filter. To change filters out, I have to remove the cover on the furnace and reach into a dark, dirty place. Naturally, it's such a p.i.t.a. that it doesn't get done as often as it should. In an effort to economize, I want to try my hand at creating a filter frame. I've found an idea location for it, just a foot away from the present location in the air return, accessible from three sides. Any references online?
Thanks!
- Wm in Kansas City
Measure with a micrometer
Mark with a crayon
Cut with an axe.
Thanks!
- Wm in Kansas City
Mark with a crayon
Cut with an axe.
