Adding Heat zones for Basement
  • old95er
    • Feb 2006
    I am finishing a basement and plan to add two aones to the existing single zone hot water baseboard heat.
    The gas fired boiler has one "circulator" pump attacehd directly to the boiler, T-stat wires go to the pump and to the boiler. The pump feeds the current one zone heat loop.
    Please help with the add on. I plan to add two circulators and two zone valves to creat the two new zones in the basement.
    There is a drain right before the circ pump and shutoff valve, can I just place a T in betweeen the current pump and the drain to feed the new zones?
    For Wiring, do I just wire from the new tstats to each valve and pump? OR do I need a switching relay? If so, do I need a three zone switching relay?
    Thanks for your help!!
  • Phelps
    • Jan 2006
    • 157
    Remember that the pumps pull and don't push, when assessing your flow scheme.
    • old95er
      • Feb 2006
      pulling pumps
      what does that mean?
      DO I place pumps in the beginning of the output loop after the boiler, or at the end of the return in front of the boiler??
      • old95er
        • Feb 2006
        controllers
        now I am wondering how to control the boiler circulator and the new circulators. . .
        Does the main circulator on my Well Mclain CG4 boiler come on whenever the boiler is on?
        Do I need to rewire with a controller?
        Should I just add two zone valves after the main circulator. How do they get power?
        I am sure this is a straightforward project, I just don't want to mess it up!!
