I am finishing a basement and plan to add two aones to the existing single zone hot water baseboard heat.
The gas fired boiler has one "circulator" pump attacehd directly to the boiler, T-stat wires go to the pump and to the boiler. The pump feeds the current one zone heat loop.
Please help with the add on. I plan to add two circulators and two zone valves to creat the two new zones in the basement.
There is a drain right before the circ pump and shutoff valve, can I just place a T in betweeen the current pump and the drain to feed the new zones?
For Wiring, do I just wire from the new tstats to each valve and pump? OR do I need a switching relay? If so, do I need a three zone switching relay?
Thanks for your help!!
