Pilot light???
  • rocklady54
    • Dec 2003
    Pilot light???
    I have been having furnace "FITS" here! Furnace went out. I Could not keep pilot light lit so I replaced the thermocoupler. Then furnace lit and stayed on fine. If I turn the thermostat up everything is fine. If I turn the thermostat down the pilot light goes out. Any ideas why this is happening?
  • albright
    • Feb 2006
    • 16
    pilot
    i would say its your gas vavle causing that prob.
      There is a small line that goes from the main valve to your standing pilot. This operates off the thermocouple which may be electrical or mechanical. I think it is mechanical, so I think you have main valve problems. One of the orifices inside may be plugged.
      • suprheat
        • Dec 2005
        • 29
        The pilot itself has a small orifice. Whenever I replace the thermocouple I clean this orifice. You have to remove the pilot assembly and remove the aluminum line from the pilot assembly - the orifice will be inside where the aluminum line screwed in. Clean by using a small wire or by air taking care not to make the hole or slot any wider than what was intended.
          Laser 730 over firing
          by hawkins111
          Has anyone had an occurrence of a Laser 730 or 731 over firing?
          The top of the heat chamber and the heat exchanger glow red on high when this occurs....
          11-12-2024, 10:29 AM
        • 911Restoration
          Fireplace Woes
          by 911Restoration
          09-22-2026, 03:14 PM
