I have only four wires coming out of wall blue,red,white,green.No old thermostat to compare to.Can someone tell me what wires go where ,i'm installing a hunter thermostat.
wiring for thermostat
Do not let the wires touch the red one when changing it out.
R -red
Y -blue
W -white
G -green
The transformer is something you can not just go pick up in any store so if you do short out the wires you could very easily loose your transformer as well as a few other components. The other components are alot less likely but the transformer is definitely at risk.
Channel: HVAC
