Broan electric furnace turned off but still blows warm?
  • chadurban
    • Sep 2010
    I have a Norton Broan 21B20M electric furnace that's about 3 years old. I recently turned the heat on and after a week or so, I noticed that it started to blow warm air all the time (even when its warmer in the house than what the thermostat is set to). I now have the thermostat set to OFF and warm air is still coming through the vents, not allot but you can feel some warm air. Its not the fan - I have that set to automatic, and when I click it to ON on the thermostat, you can hear the fan fire up. Also the thermostat light on the furnace is not lit, my owners manual says if its not lit, its an issue with the furnace and not the thermostat. I decided to turn the furnace breaker off for now.
    Anyone have any idea what the problem might be? I don't really know much about furnaces, but am fairly handy and hope I can fix this myself without calling a repair guy. Any suggestions what to check or replace? Could it be the bottom sequencer? I don't have a voltmeter on hand though to check. I had a repair guy here a few months back that was suppose to have fixed this very same problem (and apparently did), but now its back again
  • paul52446m
    • Nov 2009
    • 690
    It needs to be checked out with a tester. Could be a sequencer stuck, Or a heat relay stuck. You know that a heat coil has to be on a little or you would not be getting any heat. Later Paul
    • chadurban
      • Sep 2010
      So if i went and picked up a volt meter I would be able to test these? Any idea on what readings to look for or details on how to test them? Maybe someone knows of a website somewhere that explains in detail? LMK
      • paul52446m
        • Nov 2009
        • 690
        For me to tell you where and how and to test this unit, i would need your wiring diagram. your tester would have to test oms also.
        later paul
        • chadurban
          • Sep 2010
          Well the wife called the furnace guy before i could have a second look at it and it turns out it was the sequencer like I thought. To bad, could have saved myself $100. At least I will know the next time though, a friend of mine has a similar furnace and says the sequencer has gone a few times on theirs.
