I have a Payne 90 Plus, This winter it is blowing luke warm heat, It is taking hours to heat the house in the mourning. I looked at the burners three blue torch like flames, changed furnace filter, and nothing covering the intake or exhaust pipes outside. Everything looks the same as always same flow of air out of the registers, just luke warm air now not kinda hot like before.Its 32F outside and it took four hours to warm the house from 60F to 68F.Normally it would of taken about 45min.
Payne Gas furnace blowing luke warm
Well thats not good. Watch you burners when you have the heat turned up and see if the burners are staying on or are they cycling on and off? Another thing that could be going on is the gas pressure is low ether from the regulator outI have a Payne 90 Plus, This winter it is blowing luke warm heat, It is taking hours to heat the house in the mourning. I looked at the burners three blue torch like flames, changed furnace filter, and nothing covering the intake or exhaust pipes outside. Everything looks the same as always same flow of air out of the registers, just luke warm air now not kinda hot like before.Its 32F outside and it took four hours to warm the house from 60F to 68F.Normally it would of taken about 45min.
side or the regulator in you gas valve. Is this LP or Nat. gas? Does you pilot have wires going to it?.
What year is you furnace? Later PaulLast edited by paul52446m; 12-19-2010, 12:59 PM. -
If your burners are staying on and your air flow is the same then your gas pressure has to be too low. You need to get some one to check it. PaulComment
Do not try to adjust the pressure with out having a tester to set the pressure right. If you want to send me pic. send them to paulm989@hotmail.com
I have to work tomorrow but if i have time tomorrow night i will try to show you
how to build your own tester for testing the pressure.
I would need your pic. to tell you how to test the pressure.
Later PaulComment
If you go to Illustration, there is a post there for checking gas pressure and how to build a U tube manometer. Later PaulDo not try to adjust the pressure with out having a tester to set the pressure right. If you want to send me pic. send them to paulm989@hotmail.com
Later PaulComment
Channel: HVAC
