Hello,
I have a monitor 41. had it for for 20 years. do all the servicing on it myself.
only had to replace the ring once in all that time. my problem just started. I have a high flame in the burn chamber. when it is running on low. however when it kicks up into high the flame is back to normal untill it kicks back down to low and then the flame gets high again. I have check the tiny black rubber seal in the solenoid (why there is a rubber band there is beyond me) that open and close the flap. that little rubber seal is good no cracks in it and all in one piece. so I am at a loss as to why I am getting a high flame on low. hopefully someone here can steer me in the right direction.
Russ in North Pole, Alaska
