I have a 10 yr old 441 and i'm having problems with it staying running.
It starts goes thru it's purge,fires up on low, and switches to high.
Runs about 2 mins on high and shuts down.
I've cleaned the flame sensor and fuel tube as descibed in other threads.
It appears to be burning fine when it runs and the tip of the flame sensor is glowing red.
Just before the shut down the panel flashes one time then it turns off on a safety and flashes
i can hear the fuel soleniod stop for a second when the panel flashes come back on for a second then shuts off. It doesn't appear to be a fuel issue.
Intake fan seems to running with no issues, great air flow out the exhaust pipe
The fan switches from low to high with the burner increase and i checked the high temp limit switch which isn't causing the shut down.
I guessing the flame sensor is shot even though it's clean and in the proper location but can't believe it would run that long with it being bad.
Is the some type of thermostat that makes the unit get to temp and go back to slow burn that may have failed
Anything else i should check before replacing the sensor?
thanks
thanks
