monitor 442 fan problem
  • mahrkus
    • Aug 2012
    Hi all, have a monitor kero 442 heater and the fan runs constantly. I plugged it in and the "on" button was not even on and the fan was running. Turned it on got it running and up to temp then shut it down and fan never went off.
    Any suggestions as to what could be causing this?
    Thanks
    fan
    which fan? circulator or combustion blower?
    • mahrkus
      • Aug 2012
      fan won't shut off
      circulator fan
        • 755
        M 422 or M441
        When the circulating fan runs continuously you have either missed wired the overheat/ fan thermostat or switched the snap switches. The over heat and fan thermostats look alike but they are completely different. The overheat switches should show continuity on your meter. The fan thermostat should show an open.
        • mahrkus
          • Aug 2012
          Fan
          When the circulating fan runs continuously you have either missed wired the overheat/ fan th? fan thermostat should show an open
          Thanks Tom i will check it out.
          Mark
