Monitor 441 Question
  • grafton
    • Nov 2012
    I'm trying to reinstall my Monitor 441 and thought I remembered a O ring attached to the flue pipe where the heater slides in. Am I correct about the O ring and if so does anyone know the specs?
    Thank You
    Jerry
    • 755
    exhaust pipe O rings
    That part is referred to as Flue Pipe “O” ring, Part # 4015. It is approximately 3MM around and 40MM outside diameter. From Monitor it costs $6.00.
