Hey guys a friend of mine dropped off an old kerosun monitor 30 heater for me to repair a few weeks ago
and i rebuilt the burn chamber with new combustion ring, gaskets, cleaned out heat exchanger and blower assembly replacing all gaskets and motor bearings. I have never messed with the constant level valves and fuel systems on these units before aside from cleaning them out and replacing the filters...have never had one that was bad and had to be replaced. But the heater burned for about two weeks perfectly well and then shut off but it will burn as long as you pick up on the rod for the fuel pump.
