I have a quick question, just installed my monitor and it kept reading E 13 error, well I know that this is dust or rust or something in the pipes or low fuel.  Well there was neither.  Cleaned all of the filters the one inside the heater and the one outside at the tank.  The message kept coming up, so I tried different things...I took the Cover for the unused air intake off and the monitor is on now and working fine.  No error messages coming up.  So, my question is, does this cover have to be on?  I do not smell any fumes but I was just wondering.
MPI Monitor 2400
 air side problem
 There is a chance you have a blocked air side. When you removed the second air port you got enough air to let the stove run. If this is the case you will need to look into the flue pipe and make sure the air side is clear. A blocked air side does two things. One, not enough air for combustion, two, not enough air pressure to close the fuel pump circuit.
 I think the real issue is the fuel line had a little air in it and finally cleared itself.
 error code
 the following I copied from the 2400's error code file
 E13 No ignition. Failure of ignitor, solenoid pump
 or circuit board.
 Incorrect wiring or flame rod
 touches to burner parts.
 Air pressure switch or overheat switch
 with that in mind, check fuel flow, constant level lockout, flamerod touching the pot or the burner ring, igniter not on.
 It's early but I have found water frozen in the fuel line.
