toyostove laser 56
  • msearcher
    • Mar 2011
    • 125
    toyostove laser 56
    by chance does anyone know the type of bearing that should be used in this heater for combustion motor? Trying
    to help out a woman at work and save me a trip back to the city after I pull the bearing off.
    Do not believe they are the 608zz like the monitors (which I have plenty in stock)
    Thanks for any help and I know this is not where I should post but you all rock out there!
  • msearcher
    • Mar 2011
    • 125
    The bearings are 6mm x 19mm
    • dfitz3390
      • Oct 2010
      • 135
      did you try the same place you got your monitor bearings ?
      • msearcher
        • Mar 2011
        • 125
        Time was the issue, fastest way was to pull one and run to the bearing shop in Williston.
